Cannot format hdd
  • x3256
    • Feb 2021
    • 22
    [Misc] Cannot format hdd
    Recently got an old hdd from irAdv6275 want to use it in irA8105 but i couldn't format it using pc, is there any way to format it and then use it for another machine.
  • ReproKev
    • 273
    Re: Cannot format hdd
    Not sure if it would work, but you can try installing it in the 8105, then format it and load system software as if it was a new HDD.
    • x3256
      • Feb 2021
      • 22
      Thanks I will try this but why I cannot format hdd in pc, windows says cannot initialise disk, linux says some probe error I/o error.
        Regarding Linux have you tried pasting the error from the terminal into google?
        • x3256
          • Feb 2021
          • 22
          yes , this error "failed to probe the device udisks-error-quark 0 on sdb" also tried gparted it cannot create partition table neither dd utility is working, It looks like we cannot use canon hdd on any other device, even cannot format it.
            Have you tried the following to see the partitions, it should look something like the following (a raspberry pi)
            sudo fdisk -l
            Device Boot Start End Sectors Size Id Type
            /dev/mmcblk0p1 8192 532479 524288 256M c W95 FAT32 (LBA)
            /dev/mmcblk0p2 532480 62333951 61801472 29.5G 83 Linux
            Or you could just put the hard drive in the other copier and see if it works.
            • copier tech
              • 8142
              I recently found out it is not possible to format a newer Canon HDD in a USB caddy etc due to the HDD encryption Canon uses.
                I thought as much.
                • x3256
                  • Feb 2021
                  • 22
                  sudo fdisk -l
                  Yes drive not detected here but it's visible in disks utility
                  • x3256
                    • Feb 2021
                    • 22
                    So drive is dead now? Or they change hdd firmware, I also tried writing all zeroes using dd and it worked but again cannot alter the partition table
                      The drive can only be used in a canon copier, otherwise it's trash
                      • x3256
                        • Feb 2021
                        • 22
                        yes seems like, i did some analysis using hdparm command and found the drive is locked with some pass and its in security mode and not responding i/o commands will try ata commands to recover hdd, i dont care for data hdd is more imp for me,
                        Happy new year
