Canon IR5075 E000c0
  • adhy
    • Feb 2011
    • 109
    Canon IR5075 E000c0
    Hello there
    I got E000c0 on my Canon IR5075 ,had been reset error but still displayed .
    Any help would be apreciated
    Thank you
  • Brian8506
    • 1667
    Re: Canon IR5075 E000c0
    0010 sub code means it was not reset. Did you clear in service mode?
    • adhy
      • Feb 2011
      • 109
      I did reseting and still error'.
      • Brian8506
        • 1667
        How did you reset it? Did you use function/clear?
        • adhy
          • Feb 2011
          • 109
          By entering service mode
          • copier tech
            • 8220
            Originally posted by adhy
            Hello there
            Thank you
            [ATTACH=CONFIG]51290[/ATTACH]
            I have never seen that error code before with a lower case 'c'
            Check the heater lamp & thermo switches
            • Code: E000-0010
            • Description:The heater fails to heat. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
              The power has been turned off and then on without resetting the error.
            • Remedy:- Reset the error. (COPIER>FUNCTION>CLEAR>ERR)
              Give us a step by step process you performed.
              • adhy
                • Feb 2011
                • 109
                • Code: E000-0010
                Me too makes me confused
                • adhy
                  • Feb 2011
                  • 109
                  Additional function-28-addtional function >copier>function>clear>err>ok
                  Than restart the host machine
                  • Brian8506
                    • 1667
                    I would expect that to work. Never seen that code before either and see no mention of it in the knowledge base
                    • 20 year tech
                      • May 2014
                      • 577
                      I cant find any reference to that code anywhere, start by checking thermistors, heaters etc as others have mentioned,does the code happen with the door open ? look at the frame connectors on the machine and fixing tray, with that series jammed paper often gets wedged in them. have had to replace them for strange fixing errors before.
                      • adhy
                        • Feb 2011
                        • 109
                        Now this is happen
