C259if - Control panel black and blinking green light 2 blinks and a pause
  • MHeon71
    • Oct 2008
    • 489
    I have this C259iF with black control panel screen with the green power button. 2 blinks and a pause. I have done the troubleshooting in the manual, led 1 does not flash and no error when removing the flash PCB. I have replaced the Main Controller PCB, per manual and same thing. I find it hard to believe both boards would have the same issue. Has anyone else seen this problem? I am leaning towards power supply. I have replaced 3 at this location in 13 months and there are no more than 15 machines.
    Thank you for any assistance.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    I agree. Do a Power Supply Assembly Check Flow. (service manual)
    • MHeon71
      • Oct 2008
      • 489
      The LVPS did correct the issue.
      • zoraldinho
        • Mar 2008
        • 5007
        Thanks for the info! Good job!
