C5540i
  • soaponarope
    Pat McGatt
    • Nov 2020
    • 30
    C5540i
    Has anyone got a part number for the whole ITB assembly? Can't see one in the parts manual.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: C5540i
    Why do you need a whole unit? It would probably cost thousands!
    • soaponarope
      Pat McGatt
      • Nov 2020
      • 30
      Re: C5540i
      Because it is missing from the machine!
      • zoraldinho
        • Mar 2008
        • 5018
        Re: C5540i
        I believe it will be cheaper if you buy one used 5540.
        You also get a lot spare parts.
        • bobburnsreb
          • Mar 2015
          • 236
          Re: C5540i
          The part number for the ITB Assembly for version I and II is FM1-N260-010.
          The part number for the ITB Assembly for version III is FM1-V600-000.
          When ordering either one you are ordering all parts that are seen on Figure 530 of the Parts Manual
          The ITB Assembly includes the ITB Unit, the ITB Sheet and the ITB Outer Frame
          It does not include the ITB Cleaning assembly.
          Dealer cost $822.94
