Canon IRADV8786 error code E061-001
  • Blues977
    • Jun 2024
    • 15
    Good day guys,
    We facing a unit IRADV 8786 with error code E061-001. After the machine is in ready mode it will appear error code E061-001.(When the potential
    control is in ON in the service mode)
    When I OFF the potential control in the service mode the machine can copy and print but the image will in black copy with no image.
    We have swap the following parts and action :
    1) swap primary wire unit assembly from a working condition machine
    2) swap main DC driver P.C.B from a working condition machine
    3) Format the hard disk and re-install the firmware to latest version V36.46
    Please enlighten us if you have come across this problem, what else we need to check ? Thank you
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 167
    E061-0001-05: Potential control error (VL)
    Detection Description
    The dark area potential (VL) failed to be 200 V or less at potential control. Remedy
    [Related parts]
    - Harnesses from the Main Driver PCB to the Pre-exposure LED
    1. Main Driver PCB (UN78/J107) to Relay Connector (12P) (Unit of replacement: CABLE, MAIN, REAR UPPER)
    2. Relay Connector (12P) to Relay Connector (20P) (Unit of replacement: CABLE, AP. KIT DRAWER)
    3. Relay Connector (20P) to Pre-exposure LED (LE01/J2141) (Unit of replacement: DRAWER ASSEMBLY)
    - Harnesses from the Main Driver PCB to the Primary Charging High Voltage PCB
    1. Main Driver PCB (UN78/J111) to Relay Connector (9P) (Unit of replacement: CABLE, MAIN, REAR UPPER)
    2. Relay Connector (9P) to Primary Charging High Voltage PCB (J3501) (Unit of replacement: HIGH VOLTAGE PCB ASS'Y)
    - Harnesses from the Main Driver PCB to the Potential Sensor
    1. Main Driver PCB (UN78/J114) to Relay Connector (31P) (Unit of replacement: CABLE, MAIN DRIVER, REAR UPPER)
    2. Relay Connector (31P) to Relay Connector (25P) (Unit of replacement: CABLE, RELAY, FRONT)
    3. Relay Connector (25P) to Relay Connector (7P) (Unit of replacement: CABLE, MAIN DRIVER, FRONT)
    4. Relay Connector (7P) to Potential Sensor (EPC01/J5014) (Unit of replacement: CABLE, POTENTIAL SENSOR)
    - Harness between the Main Driver PCB (UN78/J109) and the Drum Motor (M01/J2138) (Unit of replacement: CABLE, MAIN, REAR UPPER)
    - Primary Charging Assembly
    - Laser Scanner Unit
    - Potential Sensor (EPC01) (Unit of replacement: POTENTIAL MEASURING PCB ASS'Y)
    - Primary Charging High Voltage PCB (Unit of replacement: HIGH VOLTAGE PCB ASS'Y)
    - Drum Motor (M01)
    - Pre-exposure LED (LE01)
    - Main Driver PCB (UN78) (Unit of replacement: MAIN DRIVE DRIVER PCB ASS'Y)
    - DC Controller PCB (UN01) (Unit of replacement: DC CONTROLLER PCB ASS'Y)
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the DC Controller PCB, back up the service mode data (approx. 2 min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> DSRAMRES
    • Blues977
      • Jun 2024
      • 15
      Today we have change the DC Controller P.C.B from a working condition machine now its appear different error code E0100-1130.
      Have check the laser unit seems nothing wrong with it the unit and wiring. What's wrong with this machine ?
      • tinnyjay
        • Oct 2009
        • 654
        Originally posted by Blues977
        Good day guys,
        I would change Pre-exposure LED or clean at least.
        Normally there are 3 steps to follow:
        1. Change main charger corona
        2. Change pre-exposure led
        3. Change potential sensor.
        You've gone too deep.
        "Who loves the roses,must also bear thumbs"
