user trying to scan a check and it shows up blurry? all other scans work fine.
  • wachman
    • Apr 2014
    • 50
    [Misc] user trying to scan a check and it shows up blurry? all other scans work fine.
    Is there a setting that will blur a scanned check? Security mode of some kind?
    I just installed this one everything is great! accept this issue
    any help is appreciated!
    • 23007
    Re: user trying to scan a check and it shows up blurry? all other scans work fine.
    Yes, it's called prohibited originals or counterfeit protection. It also applies to currency, stocks, bonds, and other financial instruments. A couple of typical ways around this are:
    1) select black & white scanning
    2) reduce or enlarge the image
    It's standard equipment for at least the last 10 years. =^..^=
      That info is in every service manual.
      Read up on it.
      • tsbservice
        Field tech
        • 8007
        Read up on it.
        Even in every user manual.
        OP tell them to use solution 1 from BC's tutorage.
