IRA 6055
  • Brian8506
    • 1664
    IRA 6055
    I have a 6055 with saddle Finisher E1 and punch unit. Customer did some server updates and asked me to update the firmware. Everything went smooth except there was a timeout error when it was updating the finisher. After reboot I got an E503-0002 code. Reflashed. Same thing. Code has to do with saddle stitch unit. In service mode/display/version, there's no version number for saddle stitch. DC Con, MN Con etc all updated as they should. Was told I should replace Saddle stitch controller which I have on order. Wondering if anyone else has ad this problem. I disconnected the saddle unit from the finisher controller so machine works but without the booklet maker. TIA
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: IRA 6055
    How did you update the firmware.Via CDS, sst or usb?
    • Brian8506
      • 1664
      Re: IRA 6055
      USB
      • zoraldinho
        • Mar 2008
        • 5007
        Re: IRA 6055
        Via CDS you can choose which firmware you will install. Also the oldest. I would try to return the older firmware.
        • Brian8506
          • 1664
          Re: IRA 6055
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Re: IRA 6055
            if you need smb 2/3 then special firmware needs to be installed. Once it has Special firmware, you can never update firmware otherwise it will revert back to smb 1. Other solution is scan to ftp. or scan with smb 1 to a workstation.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • Brian8506
              • 1664
              Re: IRA 6055
              I updated the latest firmware. Putting controller in the next couple of days. Will post.
