IR 8070 is not booting
  • abkonnet
    • Mar 2008
    • 166
    Hi Friends The IR 8070 is not booting the lcd display shows the canon logo and loding symbol after a minute the display blanks and again the Same canon logo is showing, the system software is not loading. I dont know what was the problem Pls help me.
  • kuby
    • Oct 2007
    • 1410
    Sounds like a hard drive failing. Try holding down the 1 and 9 key and turning ON the copier and wait for a moment and then release, the machine will start doing a scan disk (screen will blank out and the screen will start doing a series of squares dropping). It will take a while to go through the whole hard drive. Then restart when finished. If it still does not work, it is time for a new hard drive and you will have to reload the system software.
    • SCREWTAPE
      • Aug 2025
      I'm with Kuby, sounds like a bad HDD. try reloading firmware first.
      • abkonnet
        • Mar 2008
        • 166
        I need The Firmware and Service support tool
        Hi i tried to scan the hard disk by pressing 1and 9 simultaniously but the system is not booting up. i need the service support tool and firmware to install it on my hard drive. u can send it to my email id abkonnet@yahoo.co.in . Thanks. Pls help me as soon as possible.
        • 20YRSEXP
          • Oct 2008
          • 281
          How far does the boot bar get. It checks various items at different points and where the bar stops will help direct your efforts. I would reseat the boot and RAM to start. It wouldn't hurt to reseat all the connectors on the Main controller too.
          Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
          • abkonnet
            • Mar 2008
            • 166
            hi when the machine is On the canon logo and a little amount of bar is shown after a time then the bar moves and "please wait" is displayed . now only the canon logo and little amount of bar is seen the bar doesnt move. i checked all connector and even remove and refit the hard disk.
            • kuby
              • Oct 2007
              • 1410
              Hard drive is gone bad....needs to be replaced.
              • abkonnet
                • Mar 2008
                • 166
                Hi i attach the picture of the display. The only display seen on my machine after some minutes the display vanishes and again the same display. how can i fix this problem if any one can sent the firmware so i can re install it on my hard disk. pls help.
                • abkonnet
                  • Mar 2008
                  • 166
                  Hi i switch On the machine by removing one of the ram the machine shows error code 602-002 which was no start up file in HDD. now i need the firmware to put on my HDD. pls some one send the firmware to my mail abkonnet@yahoo.co.in . Tanks.
                  • SCREWTAPE
                    • Aug 2025
                    Forget about this HDD, replace it. I've seen this happen on HDD all the time, chances are always a risk when the obvious is there. You might be able to reload firmware and it might work for little period, but you would be back. Get the firmware along with a good HDD and save youself the time. If your in the states ,you can try these company's that sell and repair HDD for a fraction of the price.
                    Nation-Wide Repair Service
                    16151 Foster Street
                    Overland Park, KS 66085
                    Customer Service: 1-866-655-8676
                    Fax Number: 913-631-8372
                    Technical Support: 1-800-798-1814
                    Hytec Dealer Services
                    3600 Vineland Rd Suite 121
                    Orlando, FL 32811
                    Customer Service: 1-800-883-1001
                    Phone Number: 407-297-1001
                    Fax Number: 407-297-4310
                    Technical Support: 1-888-883-2001
                    • abkonnet
                      • Mar 2008
                      • 166
                      Tanks for the reply i am in india i cannot get service in my place for this model machine. So pls sent the firware and service support tool so i can re install in the same hard disk or in a new hard disk. Tanks.
                      • abkonnet
                        • Mar 2008
                        • 166
                        My HDD is failure
                        Hi i check my hard disk using IDE cable in computer the hard disk is not detecting. So i planned to buy a new hard disk. if so. i want to install the firmware in the hard disk in my area i can not find IR8070 firmware. The machine contains 20GB HDD can i use 40GB HDD. if some one have the IR8070 firm ware please sent it. Tanks.
                        • davidj7
                          • 1107
                          where in india are you , i can direct you to where you can get service
                          a machine is only as good as your tech : source:screwtape ; the scary one
                          • abkonnet
                            • Mar 2008
                            • 166
                            Tamil Nadu, Tirunelveli. Can u pls tell can iuse 40 Gb or 80 GB HDD.
                            • davidj7
                              • 1107
                              contact pcs in coimbatore.they will do it for you.
