Hi all, I just have another long day with Canon MF6580 Network Setup. Hope your guy can help me out. I been setup Network for many Canon copiers. But this model is the first time.
Well, I did intall all the driver for PC, input IP for copier, hood up the RJ45. I was ping from PC and it regcornize the copier. I even can pull up "Remote UI" in internet explore by the copier's IP.
So, it should be good to go. But I can't print any thing? I thought I might installed wrong driver. But after double check with the Canon Website I'm sure that I have the correct driver.
If I switch to USB then it print ok. What am I missing? Please help. Thanks
