IRA C2225 Blank copies
  • laro
    • Dec 2011
    • 18
    Hi guys, I have this IRA C2225 copier that's giving me blank copies. No error code just blanks when copying or printing. Any help would be appreciated.
  • Brian8506
    • 1666
    Re: IRA C2225 Blank copies
    Possible laser. Did you have it out or disconnected?
    • teckat
      • 16083
      Power off_
      Disconnect the Laser, now power back up, make copies & see if an Error pops up.
      • laro
        • Dec 2011
        • 18
        Thanks for your reply guys. Yes, the laser was disconnected. In fact when I checked it, one of the ribbon ends had this blue plastic support. The other end did not have it and the conductors were bent back and loose from the ribbon.I trimmed the ends and added a plastic end support. Both ends now look similar. Is that the way they should be? With laser ribbons disconnected code is 196- 001. (Tried sending pix of ribbon end connection, but no go)
        • Brian8506
          • 1666
          I believe they were the way they're supposed to be. You may want to try replacing the ribbon cable
          • laro
            • Dec 2011
            • 18
            Thanks Brian 8506 and Teckat for your responses. If anyone know where to source the scanner ribbon please let me know. If anyone can confirm if both ends at the scanner are connected the same way please let me know. God bless.
            • teckat
              • 16083
              ADVANCE C2225 / C2230 SeriesScanner Flat Cable:
              FK3-0860-000
              The flat cable runs between the scanner unit and the reader controller.
              Original Canon Scanner Unit FM0-2743-000 ImageRunner C2220, C2230+FK3-0860 Cable | eBay
              Canon FK3-0860-000 CABLE FLAT (FK3-0860-000) : achat / vente sur PC21.FR
              • copier tech
                • 8202
                FK3-0860-000
                His issue is with the laser not the scanner.
                • teckat
                  • 16083
                  Why does he mention Scanner Ribbon ?
                  • copier tech
                    • 8202
                    Lets ask.
                    Laro, do you have blank copies AND prints ?
                    • laro
                      • Dec 2011
                      • 18
                      Hi guys there seems to be a misunderstanding. I had disconnected the laser scanner unit. Thanks to Teckat's diagram I realized we were not on the same track.
                      There are 2 ends of the cable ( fk2- 9199) which connect to the unit. Need to know if both ends are terminated the same way making contact with terminals at top of socket.
                      Remember I said that i found the conductors bent back over the ribbon. I am not certain if that how it should have been. I trimmed the loose conductors and added a stiff support at the back. Is that the way it should be? Notice copier tech figured out what I was talking about. Sorry guys and thanks!
                      Yes blank copies and prints.
                      • laro
                        • Dec 2011
                        • 18
                        It's me again.Got the ribbon cable sorted out but still got blank copies. That should rule out the scanner. What next? Brian, Teckat copier tech guys, I need something because I just don't know what next to do.
                        • copier tech
                          • 8202
                          If you have blank copies AND prints yes you can rule out the scanner.
                          Are your PRINTS totally blank, no image at all, or even very faint ?
                          • Brian8506
                            • 1666
                            It could be many things but if I were standing at the guessing table I'd be focusing on the laser. I don't remember where the trigger is but you should make sure the laser shutter is working properly.
                            • laro
                              • Dec 2011
                              • 18
                              Thanks for taking the time to assist guys. How do I ensure that the shutter is working properly Brian 8506? The copies are totally blank.
