comms tests
  • MunsterTech
    • Sep 2014
    • 381
    [Misc] comms tests
    hi guys,
    we get asked to regularly perform comms tests on all our canon devices, ie. press 123, monitoring service, communications test, is there a way of setting this up so the machine will do the communications test automatically? TIA
  • Saturn
    • Nov 2023
    • 171
    As far as I know, that's not possible. A comms test is always required when the IP address/location is changed. It's to re-establish the connection to the e-Maintenance server.
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Com-test is done once when the device is connected. Once the device is entered into maintenance, you can check the communication remotely. The device will not do this on its own.
