Hi there,
This error has popped up on a few machines now. Seems to come and go. Description in manual:
Gonna check rails to see if they are loose today. Also might try replacing the connectors.
Any1 had the issue out there? If so what did you do to rectify the problem?
any help would be appreciated.
Regards
0002 Error in connection of fixing unit (hardware detection)
At normal copy, unmounted fixing unit was detected for one
moment (0.6 msec) with the front cover closed.
1.Check to see that the lever of the fixing/feed assembly has been
correctly set.
2.Check the connection of the DC controller.At normal copy, unmounted fixing unit was detected for one
correctly set.
Regards
