IR 4225i help. Firmware
  • Alexandr
    • Mar 2022
    • 12
    I have an IR 4225i. Scans only SMB 1. Help how to make SMB 2? Give the firmware where the SMB 2 will be
  • copicatt
    • Nov 2008
    • 366
    Re: IR 4225i help. Firmware
    I'm not sure the firmware updates that item. You can turn smb1 back on in windows to allow it to work, but IT dept may not want that back on.....
    • Alexandr
      • Mar 2022
      • 12
      That is the problem. The internal policy of the company prohibits scanning via SMB 1. On the IR 4025i, the firmware helped and there it became possible to scan via SMB 2.
      • copier tech
        • 8195
        Happy to help with the SMB 2/3 update.
        Printer & Copier Firmware - www.printerfirmware.co.uk
        • Alexandr
          • Mar 2022
          • 12
          Originally posted by terramobil
          If the machine has access to the internet, you can a install the special firmware "V25.59.46.68" in service mode to support SMB V2/V3.
          Made an update as you wrote. After the update, the LAN network stopped working. What to do? Can you tell me where it needs to be enabled?
          • copyhere
            • May 2009
            • 112
            Hello, I am having the same issue. does anyone know the registration id and password to download the special firmware from cds server?
            Thanks.
            • ADV COPIER
              Pemain
              • Nov 2022
              • 259
              drop your email, I can help you
              Let's Drink our Coffee
              WhatsApp +62895325228383
