Strange jam problem with Advance C5235
  • campy
    • May 2012
    • 315
    I have a customer that developed this problem out of nowhere. He's telling me when he prints it's showing that it jammed but there's no paper in the copier. When I check the jam history it's showing a jam in the document feeder at S14 sensor. If he opens and closes the right door it prints everything out with no problem. I reinstalled the system software but it's still does it. He just called me and told me it has been fine all day until the end of the day it did about 5 times. It does it out of both tray 1 and 2 so it's not a feed problem. Copying it doesn't seem to be a problem but most things are printed. Any ideas?
  • GIUBOSS
    • 1385
    Re: Strange jam problem with Advance C5235
    You are sure that all of the drawer feed rubber rollers are in good condition and that there is no paper piled up behind them. Check and clean the paper sensors as well.
    • campy
      • May 2012
      • 315
      Yes they are good.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5003
        Replace sensor showing in jam history.
        • campy
          • May 2012
          • 315
          It's showing a jam in adf at sensor S14. It happens when printing not copying.
          • zoraldinho
            • Mar 2008
            • 5003
            Are you saying there are no jams in the jam history?
            • campy
              • May 2012
              • 315
              As stated above it's showing jam in adf.
              • Venom
                Technical/IT Support
                • Nov 2009
                • 765
                Look at Alarm codes and Error codes. Often these will show what triggered jam message.
                IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
