Loading Firmware Replaced Hard Drive Canon IRAC 55XXi Series machines
  • chrisban35
    • Jan 2011
    • 197
    I'm a Xerox dealer but I also really like the Canon products. So I have quite a few of them in the field. Recently I had to replace a hard drive on a Canon C5540i and was told by a fellow tech, I just needed to load the firmware onto the USB, plug it in, and turn the machine on and it would auto load from the USB and onto the new Hard drive.
    Obviously, I now see that doesn't work. With Xerox we load a file we create called "Forced Boot" Or proper lingo "Alt_Boot" and then follow the same above mentioned steps. But with Xerox our operating system isn't on the Hard drive.
    So my question is, can someone please tell me the steps I need to get the new Hard Drive to accept the firmware? My client is down and I need to come up with a solution pretty quick. Thanks in advance to anyone who offers help.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5007
      Re: Loading Firmware Replaced Hard Drive Canon IRAC 55XXi Series machines
      As Ken said the disc must be for the right model.
      Upload firmware to USB using SST. If you haven’t done this yet, you’ll probably have problems.
      Press and hold numbers 2 and 8 on the keyboard and turn on the printer. Insert USB.
      Format the disk then install the firmware (update auto).
      • chrisban35
        • Jan 2011
        • 197
        Thank you both for your input. The one that's in the machine is Toshiba, but I've seen some with Hitachi, so I was using the Hitachi version. I have the proper firmware on the USB and had done it successfully before, I just forgot the 2 and 8 key, format HD part..
        Correct me if I'm wrong, but the one part which was most important was making sure it was the exact same GB size too. The machine had a "Toshiba MQ01ABF032" HD which is 320GB." I'm attempting to replace it with a Hitachi 0J11523 - 320GB HD"
        Also, I do not have the SST software on my laptop since I'm not an authorized Canon Dealer. Is there somewhere I can go and download this software? I'd sure like a copy of it since I work on so many of them.
        • chrisban35
          • Jan 2011
          • 197
          One last question to go along with my first response above.....On the thumbdrive, do I leave the unzipped firmware files in the "folder" that it creates, or do I move everything in that folder out to the root of the drive?? ie E:/files or E:/Folder/files??
          Thanks!
          • bobburnsreb
            • Mar 2015
            • 232
            Gen 3 devices (all editions - C55xx, 45xx...etc...), when needing to format the HDD, after the format is complete just cycle power. The System Software backup resides on the Flash PCB. Canon hard drive part number FK4-1550-000. We order from Hytec at about $80.00 Also you unzip the file to the root directory if you are working with firmware.
            • chrisban35
              • Jan 2011
              • 197
              Thank you sir! Much appreciated! So I'll assume, I just insert HD, Power on using 2 and 8 key, go to format HD, once complete, simply doa Cycle Power and the internal Flash will do the rest? Or leave the USB in place with all files at the root?
              Sorry, you know us Xerox Type, we need it in Crayon! LOL
              • bobburnsreb
                • Mar 2015
                • 232
                Just replace the HDD and reboot the machine in 2+8 and format. you got it right. you can leave the usb in until all is good.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Thanks!
                  You have to extract then register on sst the transfer to usb using sst
                  Regards Mark
                  • fchu5959
                    Field Engineer
                    • Jun 2010
                    • 100
                    Hi,
                    What make you think that the HD is at fault?What was the issue? Did the machine pop up any error code or shows any other symptoms?
                    Ifever it happens that you have to replace the HD,then ,no doubt, you will have the answers here;
                    Regards
                    • Dc Alex
                      • Jun 2022
                      • 13
                      hello mastercosot of the firmware canon c7570i and c5560i??
                      • marc1725
                        • Apr 2023
                        • 6
                        good day my fellow tech.,i have also same problems canon 5540i e602 i want to replace the harddisk but my problem i do not have a firmware for that model anyone here have a firmware for canon 5540i?thanks
                        • dekoster
                          • Aug 2012
                          • 84
                          ich habe diese Festplatten
                          ddk@ajruli-kopiersysteme.de
                          aus Deutschland Dortmund
