Canon Image Runner Advance C5045 paper jams running letter in the non "R" direction.
  • tonerjockey
    • Apr 2014
    • 573
    Hi Guys,
    this thing had me running nuts,
    it was jamming (stopping) intermittently on longer runs. i switched the letter and legal paper in drawers 1 and 2, same thing.
    the paper isn't folded, or crumpled. just laying flat in the 3 places when it stops.
    and the image appears to be in the correct location on the ones that have transferred.
    i noticed that the little plastic roller was missing on the post fuser paper sensor actuator, ? fuser delivery guide.
    i replaced that and also the paper feed rollers. cleaned the vertical transport driven rollers, lubed the one that has a one was pin clutch, and blew out the various paper sensors. some i hope the air got to the right place.
    same thing.
    the service mode jam code is 0213 00. there were some 0205, and 0107 as well.
    i also tried the bypass tray with the paper in the R position and it didn't jam.
    then i decided to turn the letter size paper in drawer 1 to the R direction, and it didn't jam.
    i have had this in various brands over the years, sometimes telling them to just load it that way. but i believe that they loose substantial ppm print speed in this configuration, so i hope to get to the bottom of this if possible.
    if anyone has any recollection of this now, i guess older model, i would be so grateful.
    thank you very much for any input of advice.
    have a great Memorial holiday, Jim.
  • Andyboachie
    • 185
    Re: Canon Image Runner Advance C5045 paper jams running letter in the non "R" directi
    Originally posted by tonerjockey
    Hi Guys,
    same thing.
    From the detail you've given ( "bypass tray with the paper in the R position and it didn't jam";
    "letter size paper in drawer 1 to the R direction, and it didn't jam"), I presume any R-position in both cassette and bypass trays will not jam.
    What of a feed of paper through the bypass without R-position? Does it jam? If this does not jam, I will suggest a change of Cassette Pickup Assembly to deal with problems with Preregistration. If the bypass also jams without R-position, I will suggest you work on the Registration Sensor with its flag, as well as Registration Clutch (CL1).
    • tonerjockey
      • Apr 2014
      • 573
      Thank you very much Andy.
      i will get to work in that direction. i really appreciate your input.
      have a very mice day.
