E025-001 IRA8095
  • jiongpao
    • May 2009
    • 414
    E025-001 IRA8095
    Hi. I got a problem with ira8095 that it will come out the code of e025 every 3-4 days. Inside the buffer assy the toner always full and i need to throw some to get rid the code but the code came back after every few days. Anyone encounter this code?
  • Brian8506
    • 1667
    Re: E025-001 IRA8095
    Product : imageRUNNER ADVANCE 6075 / 6065 / 6055imageRUNNER ADVANCE 8105 / 8095 / 8085imageRUNNER ADVANCE 6255 / 6265 / 6275imageRUNNER ADVANCE 8205 / 8285 / 8295imageRUNNER ADVANCE 6575 / 6565 / 6555 imageRUNNER ADVANCE 8585 / 8595 / 8505
    Title : E025-0001 Error Code
    Error :
    E025-0001 Error Code is an over current of the Toner Feed Motor (M28).
    Workaround :
    During the troubleshooting process the Toner Hopper, Toner Feed Motor (M28) and Main Driver PCB were all replaced.
    Performing a part check on motor M28 came out ok.
    The way to perform a part check is by going into Service Mode>Copier>Function>Part-Chk then set MTR to a 2 and highlighting MTR-ON and selecting the ok button.
    The Buffer Unit auger was inspected and was spinning freely. Vacuuming out the Buffer unit also had no effect.
    Replacing the Buffer Unit ultimately resolved the issue
    The following image is of the Buffer Unit Part and Location in the Parts Manual.
    • jiongpao
      • May 2009
      • 414
      Error :
      Workaround :
      Change M28 motor the error code still came out after 2 days
      • Brian8506
        • 1667
        Maybe try the whole buffer unit
        • Brian8506
          • 1667
          Stupid question but did you check that the toner bottle is in properly? If not it could cause an e-025
          • jiongpao
            • May 2009
            • 414
            Ok i will check the toner bottle position. Never cross my mind toner bottle will cause e025
            • HUYNH HUU HOANG
              • Jun 2022
              • 6
              https://www.youtube.com/channel/UCaEwLuLFdeXkqHOWKMoaIBQ
              • jiongpao
                • May 2009
                • 414
                Hi. The toner bottle inserted properly and it rotate smoothly i changed the new M28 motor on buffer unit. I checked and cleaned inside buffer unit there is no broken pin stuck. The E025 code still came out after 2 to 3 days.
                • TEST10
                  • Jun 2010
                  • 69
                  ...I would try to change the toner sensor
                  • Canuck
                    Tech Specialist
                    • 1713
                    Make sure the shutter on the bottom of the buffer assembly is pushed open properly when the dev is inserted. I've seen the plastic clips fall off and the shutter doesn't open and the buffer unit is packed. Dev full of toner and are it's stirring rods ok?(they break). Try another buffer unit(a used one out of any 6000,6200 will work in an 8000/8200 series also).
                    • jiongpao
                      • May 2009
                      • 414
                      The plastic clip still attached and i manually play around with the shutter it work fine. stirring rod still ok. I will try on CL5 clutch on the rear side next time it come out the code again
