iRADC 5250 can't enter service mode
  • Blues Guy
    • Aug 2009
    • 216
    Good day everyone,
    Facing a problem iRADVC5250 can't enter the service mode to clear the password.
    When you power on the machine prompt a log in display to enter user name and password. End user have forgot the password hence we try to
    enter into service mode want to clear the password. Unfortunately the machine can't enter the service mode.
    We change the whole control panel assembly but still the same. Any solution that you guys can advice ? Thank you
  • darknet93
    • Nov 2015
    • 89
    Re: iRADC 5250 can't enter service mode
    Originally posted by Blues Guy
    Good day everyone,
    Have you try to E355* CLEAR ALL RAM ? or just do Format HDD and reupdate Firmware ? normaly it will solve the problem.
    • Blues Guy
      • Aug 2009
      • 216
      Hi Darknet93
      Thanks for your suggestion. For your info I have swap from another unit working machine the control panel and today change
      the HDD still the same. Can't go into service mode when you press * 2&8*. Attach with photo that the display when you power
      the machine.
      • darknet93
        • Nov 2015
        • 89
        Hi Darknet93
        the machine.
        have you try the * 1&7 3&9 * service mode ? from there you can try e355* clear all ram
        WhatsApp Image 2022-06-23 at 11.48.33 AM.jpg from here select 01 WhatsApp Image 2022-06-23 at 11.48.34 AM (1).jpg then highlight the e355 clear all ram and press 2 then press OK at the right bottom
        • Blues Guy
          • Aug 2009
          • 216
          [ATTACH=CONFIG]53769[/ATTACH] from here select 01 [ATTACH=CONFIG]53770[/ATTACH] then highlight the e355 clear all ram and press 2 then press OK at the right bottom
          Ok will try this method enter factory mode to clear it. Thank you very much for your idea.
          • giogi
            Engineer senior
            • Jan 2016
            • 181
            for enter in service mode, can you try *49*
            COPIER > OPTION > FNC-SW > SVMD-ENT
            "Knowledge is a source, but unfortunately ignorance is a sea."
            • sengleap
              • May 2020
              • 3
              I have problem with Canon IR ADV 6255, CAN'T ENTER SERVICE MODE (*28*)
              1. I had enter *49*
              2. Clear Option and MMI
              3. Restart machine then *28* can be entered.
              It works for me
              Thank you for your comment.
