IR 7095 NETWORK PROBLEM
  • lmolina
    • Jan 2008
    • 20
    [Dead] IR 7095 NETWORK PROBLEM
    Dear friends I have the following problem. In a storm I had a power outage and my machine started acting weird. When you turn it on, it does its normal process, and is ready to copy. The detail is that it no longer recognizes the network and I can no longer print with it. The lights on the network card do not turn on. On the other hand, when you want to turn it off, it gets stuck and never turns off.
    I'm thinking that the system software has been damaged, but I don't know what to do since it could also be that the integrated card is no longer working.
    Could it be that the system software got damaged? Could you start by trying to repair that part to see if the network card is corrected or, in your opinion, it no longer has a case and you think the network card is already ruined?
    Thank you very much for your reply.
    just who has the right to live a good reason for being willing to die
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: IR 7095 NETWORK PROBLEM
    A few questions here;does the printer do normal copying without any problem,
    When you configure the printer with the assigned ip address and ping the printer do you get the connection results?
    • kuby
      • Oct 2007
      • 1411
      I would say the network card it toast. Was it on a surge protector that protected the power plus the network card?
      • nicknt82
        • Nov 2011
        • 155
        Try Clear -All Items, Reload Firmware. If can't solve, MainController got faulty surely
