Hello,
I have a IP c710 with color issue whenever i try to calibrate the machine through the gradation sensor.
Each time i calibrate a different result of colors i got . Check the photo attached. All the results are way far from the correct colors.
First of all the machine have no scanner .So i cant swap the gradation to using scanner.
I cleaned all the sensors in the engine , patch and registration sensors , black patch. Gradation sensors . Cleaned all the lasers (all glasses & polygon).
Tried different patch sensor. Tried different p-pascal values . All without any improvements.
All the PG results are good . Machine is having this issue ever since it was installed. Total counter around 400K only.
Tried doing a full format . Installed newest firmware. Cleared DC all without any improvements.
Any suggestions what would be the cause of this issue ?
Sent from my M2101K6I using Tapatalk
