Canon IR 4235 with light copies
  • moetzmoet
    • Jun 2022
    • 4
  • giogi
    Engineer senior
    • Jan 2016
    • 181
    Re: Canon IR 4235 with light copies
    please check
    Settings/Registration : Function Settings : Printer > Custom Settings > toner save > OFF
    "Knowledge is a source, but unfortunately ignorance is a sea."
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Clean the laser unit
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • COPIERTEC ASSOCIATES
        • Aug 2011
        • 279
        The fact that the font report is ok ,it means the laser unit is ok.
        Try to clean the optical fibre on the scanner with a cotton wool or clean cloth with spirit.
        If the copy is still faint clean the transfer roller as well.
        If no copy improvement still,under service mode go to COPIER>ADJUST>DEVELOP and make adjustments.
        • tonerhead
          • Sep 2009
          • 582
          Had same issue a while back. Didn't make sense. Asked for help and one of our techs had battled the same issue a while ago. In my case going into full automatic gradation setting took care of it. I had to run it twice, each time it got much better. Don't ask me why, just try it and see if it works for you too.
          I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
          Especially when it comes to sex
          • Venom
            • Nov 2009
            • 765
            The way I read it was the font prints are OK (to me means not great), would be easier to help if we could see samples.
            Guess I shouldn`t assume that optics were cleaned and auto gradation ran.
            • nicknt82
              • Nov 2011
              • 155
              Also repalce H.V.T PCB if all methods can't solve
