Canon IR 4235 with light copies
Re: Canon IR 4235 with light copies
The fact that the font report is ok ,it means the laser unit is ok.
Try to clean the optical fibre on the scanner with a cotton wool or clean cloth with spirit.
If the copy is still faint clean the transfer roller as well.
If no copy improvement still,under service mode go to COPIER>ADJUST>DEVELOP and make adjustments.Comment
Had same issue a while back. Didn't make sense. Asked for help and one of our techs had battled the same issue a while ago. In my case going into full automatic gradation setting took care of it. I had to run it twice, each time it got much better. Don't ask me why, just try it and see if it works for you too.I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
Especially when it comes to sexComment
Guess I shouldn`t assume that optics were cleaned and auto gradation ran.IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
