Canon IR 8070 Paper Jam
  • abkonnet
    • Mar 2008
    • 166
    Hi friends my canon IR 8070 getting paper jam. The paper Jam is happened below drum the Unit. I dont know the name of the unit(Unit before the belt). Also the unit is not firmley fixed can any body sent the photo of the unit how it is fixed.
  • SCREWTAPE
    First there is the registration assy, then the transfer separation corona assy, then the transport belts.
    • abkonnet
      • Mar 2008
      • 166
      I have attach the Photos
      Hi i have attach the photos. The unit where the paper jam happen is not fitted firmely. Pls go through the Pictures. Can any body sent pictures how the unit is fixed in other machines 8070 machines.
      • ReproKev
        • 273
        Thats a pretty common problem. I used to see it on IR-600's and 8500's fairly often. The metal brackets that hold the registration assm are bent. You need to remove the registration assm, straighten the bent brackets and reinstall the reg assm.
        • abkonnet
          • Mar 2008
          • 166
          Hi friends The paper Jam is ok now but the edges of the paper are folding when printing two sided copies. Why?
          • 20YRSEXP
            • 281
            Is it folding only on two sided? I would check the duplex tray. When you lift the large cover on the duplex thru tray there is a small guide that the cover rests on. There should be a tab on the front and rear side of the lower guide. If these tabs are broken the corner(s) will bend.
            Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
            • shazza
              • Nov 2009
              • 96
              I am after part number for registration assy and reg clutch on a 8070. Apparently they differ to a 8500?
              Many Thanks,
              Shazza
              I have FG6-7290-030 AND FH6-5014-020 (8500)
              • Canuck
                Tech Specialist
                • 1713
                Replace the white plastic clutch cover also...they break where the clutch "anchors" on it. Noticed 010B jams also...clean fuser inlet guide,inside of transport belts, check fuser drives,transport fan operation
