Canon IR adv 6275 Error 000-000
  • Anjaskaseto
    • Nov 2014
    • 55
    [Error Code] Canon IR adv 6275 Error 000-000
    Hello everyone....
    can anyone help my problem.
    I have a canon IRA 6275 that costs E000-000. I have changed the IH Power Supply and Maindrive, Fixing Assy but the problem is not resolved.??
    maybe there is another way that I haven't doneWhatsApp Image 2022-09-01 at 14.29.16.jpgWhatsApp Image 2022-09-01 at 14.29.16 (1).jpgWhatsApp Image 2022-09-01 at 14.29.17.jpg
  • copier tech
    • 8167
    Re: Canon IR adv 6275 Error 000-000
    Originally posted by Anjaskaseto
    Hello everyone....
    maybe there is another way that I haven't done[ATTACH=CONFIG]54522[/ATTACH][ATTACH=CONFIG]54523[/ATTACH][ATTACH=CONFIG]54524[/ATTACH]
    Did you reset the code in service mode ?
    • Anjaskaseto
      • Nov 2014
      • 55
      no, I'm just trying to clear the error
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5015
        Even when you replace the broken part, the error will not be resolved until you reset the error.
        • Brian8506
          • 1665
          Alot of work considering the problem is probably in the fuser if it doesn't reset. Go into service mode, function, clear,err,ok.
          • Anjaskaseto
            • Nov 2014
            • 55
            I have done this repeatedly, but the problem has not been resolved
            And now the Error code changes to E732-999
            • TEST10
              • Jun 2010
              • 69
              I would check the connector, between the fuser and the chassis (it may be broken or with pieces of paper) good luck
              • Brian8506
                • 1665
                Did you try replacing the thermistor or the heating element?
