Hello.
I have a Canon C165 model machine. When the customer came to turn it on, in the morning there was no response as if you had not pressed the start button. We checked the electrical outlet and found it 220 volts, as well as the power cable, as well as the circuit breaker, and we also tried another AC driver board and there is no response.
Kindly helps.
Sent from my HRY-LX1T using Tapatalk
Kindly helps.
