Printing Suspended
  • Chaw
    • Mar 2009
    • 48
    Printing Suspended
    Hello to all I am having an issue with an IRC 5185, when trying to copy or print the Copier comes on like its ready to print the screen shows that the Print Job is suspended. The Error light starts to blink and the copier gets stuck, and sugestions wll be greatful thank you guys in Advance.
    Thank you
  • SCREWTAPE
    Do you have a imagepass connected?
    Do you have dept id codes set up?
    At what point did this begin?
    • Chaw
      • Mar 2009
      • 48
      Yes the Image Pass is Connected i assume it started within the past few days just got the service call today, as far as the dept key I will check with IT and make sure all the server and log in detials are entered and correct.
      Thank you
      • SCREWTAPE
        Thank you
        Check the imagepass and see if the imagepass is on resume printing and not Suspend.
        • Chaw
          • Mar 2009
          • 48
          Thank you will take a look at the setting and see what the setting are
          • SCREWTAPE
            Also check the finisher and the staple cartridge..
            If it has one.
            • Oze
              Ricoh Fanboy
              • 1663
              Yeah screwy...I've seen that issue with iR5055 finishers...if it runs out of staples you can forget about printing.
              • mtech
                • Mar 2007
                • 307
                Replace the staple cartridge! Seen this so many times!
                • Chaw
                  • Mar 2009
                  • 48
                  working
                  Thank you guys for your help it turned out to be there was a piece of paper jammed in the fixing unit and had to put staples in also
                  thank you
