IRADVC256 - E074 -002
  • MunsterTech
    • Sep 2014
    • 381
    [Error Code] IRADVC256 - E074 -002
    have a colleague who has the above error code on a C256, he has replaced the ITB but says the error does not clear. I am getting him to check connections on the DC etc but looking at the ITB release Switch assy or the main drive assy which has the primary disengagment solenoid, seems to be alot in the SM. The machine has less than 100k on it and is only 3 yrs old, so not a heavy worker. Has anyone seen this before on this model?
    • 16083
    Re: IRADVC256 - E074 -002
    Originally posted by MunsterTech
    First questions I ask tech , was code on printer before you arrived ?
    Or code appeared after u worked on printer ?
    • MunsterTech
      • Sep 2014
      • 381
      Says the the call was logged for the E074
      • fchu5959
        Field Engineer
        • Jun 2010
        • 100
        Before the code popped up,if you have had blank copies,clean the primary disengagement solenoid SL01 found in the main drive.
        If the machine is working in a hot and humid environment,the solenoid plate become sticky with time.
        i hope this would solve your issue.
          • 16083
          Ok
          Now question customer on what they experienced before code.
          • nathicana
            • Aug 2008
            • 335
            I agree with the above comment that the problem is within the main drive unit. I have replaced the whole unit for this problem.
            • MunsterTech
              • Sep 2014
              • 381
              hi guys,
              thanks for all the responses, luckily enough, had a scrap machine available, so took the main drive out, replaced it in the machine with the E074 and now working away like a good un!
              thanks again
              • cipinet
                • Jun 2019
                • 6
                Today I have Canon c351 with same error. Just remove 2 PCBs and you have access to clutch, remove sticky sponge and stick something thin between metals.
                • bitels85
                  • Jun 2015
                  • 9
                  I want to thank You so much !!! I've had the same error in C250 and your suggestion turned out to be the solution I need Once again thank You and good day sir!
                  • Alex1
                    • Oct 2012
                    • 287
                    Hi, i pulled off this part and got to the solenoid and i cant see the sponge anywhere. Type
                    • cipinet
                      • Jun 2019
                      • 6
                      What Do Printer Solenoids DoSolenoids are a simple electromechanical devices typically found in printers. The solenoid's function is to hold back a spring-loaded gear and control its movement to open and close, allowing the gear to spin and pick up a piece of paper. In printers, solenoids are commonly used in mechanisms such as paper feeders and paper trays to regulate the movement of gears and other mechanical parts involved in the paper handling process. This controlled movement ensures precis
                        • 8200
                        Out of interest how long / how easy was it to replace the main drive unit on this A4 machine ?
                        • Alex1
                          • Oct 2012
                          • 287
                          I didn't say I replaced it, I did pull it out however I'm trying to see where the sponge that goes sticky is located as i can't see it.
                          • doktor
                            • 215
                            Open the link and everything will be clear to you!
