Canon ADV4525i III jam 0107 when printing/copy 2-sided
  • apoxi
    • Nov 2015
    • 45
    [Jamming] Canon ADV4525i III jam 0107 when printing/copy 2-sided
    Hi,
    We have a problem with canon ADV4525i III. When printing duplex (not every print) jamming (see the picture).
    1.sided working BP!!!!!!!!!
    The sheet of paper stays right in the drum unit instead of going to the fuser unit.
    The fuser unit is new!!!
    Any idea?
  • wcanonw
    • Aug 2014
    • 404
    Re: Canon ADV4525i III jam 0107 when printing/copy 2-sided
    Originally posted by apoxi
    Hi,
    The jam code is 0107[ATTACH=CONFIG]55057[/ATTACH]
    Any idea?
    TR-TP-TM 1 Adj transfer lead edge weak bias time
    Detail This mode determines the time to apply voltage for transfer leading edge weak bias during the
    second printing of 2-sided..
    +: The application time increases.
    -: The application time decreases.
    When the fixing delivery delay jam occurs, increase the application time.
    Use Case This item is used when the fixing delivery delay jam (0107) of the 2nd side of 2-sided occurs in the
    following condition.
    - High temperature/high humidity environment
    - The cassette heater is ON
    - Use of the thin paper 1 and plain paper 1/2
    Adj/Set/Operate Method Enter the setting value, and then press OK key.
    Caution When the transfer bias level (TR-TP-LV) is increased and the application time (TR-TP-TM) is too
    shorter, the jam may occur easily.
    When the transfer bias level (TR-TP-LV) is decreased and the application time (TR-TP-TM) is too
    longer, the leading part of the image becomes light.
    When the setting of TR-TP-LV is not 0, the setting of TR-TP-TM becomes effective.
    Display/Adj/Set Range 0 to 127
    Unit msec
    Default Value 0
    Related Service Mode COPIER> ADJUST> HV-TR> TR-TP-LV
    Amount of Change per
    Unit
    • wcanonw
      • Aug 2014
      • 404
      TR-TP-LV 1 Adj transfer lead edge weak bias level
      Detail This mode determines the level to apply voltage for transfer lead edge weak bias during the second
      +: The output level increases.
      -: The output level decreases.
      When the fixing delivery delay jam occurs, decrease the output level.
      Adj/Set/Operate Method Enter the setting value (switch negative/positive by -/+ key) and press OK key.
      Display/Adj/Set Range -50 to 50
      Default Value 0
      Related Service Mode COPIER> ADJUST> HV-TR> TR-TP-TM
      Unit
      0.01
