Firmware C5030i
  • jimmydenhaag
    • Oct 2022
    • 18
    Firmware C5030i
    I was previously provided with firmware for the canon c5030i.
    Only the names of the folders are different;
    The folders iAC5051 + iAC5255. And the files iAC5051-Xxxx0621-HDformat.ift + iAC5255-Xxxx0617-HDformat.ift
    Are these the correct files?
    Thanks!
  • andinoag
    • Dec 2022
    • 6
    Re: Firmware C5030i
    I have a problem with file iAC5255-XXxx0671-HDFormat.ift
    When I try to format HDD the display show up the message:
    ////Hard disk format///
    ///Formating HDD. Do not out power.///
    [ERROR]. Cannot read the format file
    Formating HDD(ALL) ... Error
    Hdd format ... Error
    Remove USB device them shut down.
    --- Please hit Reset key to start shut down. ---
    I thought the .ift is bad.
    Please, can anyone help me with this file?
    Thank you 👍🏻
    • copier tech
      • 8169
      Re: Firmware C5030i
      Thank you 👍🏻
      Where did you get the HDD from & was it new ?
      • andinoag
        • Dec 2022
        • 6
        Re: Firmware C5030i
        This is the same model and brand new.
        With another and old one the error still the same.
        • ADV COPIER
          Pemain
          • Nov 2022
          • 256
          Re: Firmware C5030i
          what is you mail, I send it
          Let's Drink our Coffee
          WhatsApp +62895325228383
          • andinoag
            • Dec 2022
            • 6
            Re: Firmware C5030i
            andinoag @ gmail com
