laser class 510 scan problem
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I do not do a lot of Cannons but got ask to look at this for a customer. If scanning through the document feeder, page comes out blank. Works good off the glass. Scanner seems to be going to correct position. Is this something simple I missed. I also ran into an different modle cannon that prints blank from the glass, and if you use the document feeder, you get 2 long square black strips down the page. Is stuff like this common with Canon?
  • wingnut132
    • 65
    You need to replace the ribbon cable Part# HH2-3222-000. It is common on those machines, just did one last week.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      How many different models would that part number fit. Is this common for all laser class with slit glass scanning?
      • wingnut132
        • 65
        So far I have only had the problem with the 510
