IR ADV C7280 with E04-502
  • tinnyjay
    • Oct 2009
    • 666
    Hi guys,
    I have an Ir Adv c7280 (same as c7260) and it gives E04-502.
    Changed fuser unit, change fuser drawer and drawer into the machine but when i have to open fuser drawer bcs a misfeed, it shows E04-502.
    After restart everything is OK but if i have to open drawer and close it again, i will face the error.
    Can you help me please?
    "Who loves the roses,must also bear thumbs"
  • wcanonw
    • Aug 2014
    • 404
    Re: IR ADV C7280 with E04-502
    Originally posted by tinnyjay
    Hi guys,
    https://www.copytechnet.com/forums/c...E004:confused:
    • tinnyjay
      • Oct 2009
      • 666
      Not my case.
      I have changed both fuser connector and body/interior connector but still the same.
      The problem looks deeper. Could be a faulty Relay PCB but i am not sure.
      Thanks anyway
      • wcanonw
        • Aug 2014
        • 404
        Not my case.
        Thanks anyway
        Hello, you must verify all the drawers:
        fixing unit
        FIXING/FEED ASSEMBLY
        • wcanonw
          • Aug 2014
          • 404
          Also check the wiring or any connector that is causing false contact, check if the drawers are making good contact when closing or pushing the FIXING/FEED ASSEMBLY
          • wcanonw
            • Aug 2014
            • 404
            What paper jam code appears?
            • tinnyjay
              • Oct 2009
              • 666
              fixing unit
              Changed with new ones
              • tinnyjay
                • Oct 2009
                • 666
                Changed fuser unit and interior fixing connector with cables also.
                • tinnyjay
                  • Oct 2009
                  • 666
                  Different ones. Depend on what paper or size i am using.
                  Also it happens when the machine is idle, i open and close fixing unit.
                  • tinnyjay
                    • Oct 2009
                    • 666
                    Re: IR ADV C7280 with E04-502/Solved
                    SOLVED
                    Fixing drawer switch under duplex was faulty. Nonsens at all, but that was the prob.
                    Thank you guys
