Replace the waste toner
  • magesh
    • Apr 2022
    • 30
    [Misc] Replace the waste toner
    HI,
    My canon c5030 error showing as Waste toner near end replacement not needed, but after i clear out the wast toner and put it back the wast toner container error showing as Replace the wast toner container, idk why earlier its shows replacement not needed, but now replace the waste toner error showing,
    anyone help me on this,
    Regards,
    Magesh
  • copier tech
    • 8221
    Re: Replace the waste toner
    Originally posted by magesh
    HI,
    Regards,
    Magesh
    Did you clean out the clear window on the bottle? Also check the sensor is also clean/blown out.
    • magesh
      • Apr 2022
      • 30
      [ATTACH=CONFIG]55872[/ATTACH]
      Thank u so much just now i noticed that it works fine,
      Thank u so much for ur valuable feedback,
      Regards,
      Magesh
