Canon C3525 image issue at top of page only
  • tbsl
    • Oct 2014
    • 16
    Hi
    I have a weird problem that has stumped a few engineers here. The image below shows at the top of each page these four marks as highlighted. We have changed drums, fuser, belt, devs but to no avail. Done the maintenance routines etc.
    Does anyone have any pointers as to what the problem is please?
    Thanks in advance
  • Brian8506
    • 1667
    Re: Canon C3525 image issue at top of page only
    Small rotational pattern. What about the transfer roller
    • tbsl
      • Oct 2014
      • 16
      Hi
      Thanks for the reply. We actually have just changed the complete right hand side door from another machine but still the same issue. Running out of ideas on this one
      • nathicana
        • Aug 2008
        • 335
        Originally posted by tbsl
        Hi
        Could someone have loaded paper into the machine that has these marks already on it?
        • fchu5959
          Field Engineer
          • Jun 2010
          • 100
          [QUOTE=tbsl;2269315]Hi
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            Only 2 things can cause dots like that. Contaminated charge roller or a blob of toner on Dev unit mag roller.
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • fchu5959
              Field Engineer
              • Jun 2010
              • 100
              I agree with the charge roller but the drums as well as the devs and the fuser have been replaced!!!
              How is the paper fed? A4 or A4R?
              Does it occur on copy and prints as well?? and from all paper sources??
              We need more informations to narrow down the issue.
              • Brian8506
                • 1667
                You said he changed all the drums. Did you change the whole drum units or just the cylinder?
                • bobburnsreb
                  • Mar 2015
                  • 236
                  [Cause]The image failure occurs when rollers have foreign matters or flaws.[Service work]Check the rollers or gears of a) to m) below.
                  No interval (xx pitch) Parts Parts No
                  a 94mm Photosensitive Drum Drum Unit
                  b 44mm Primary Charging Roller Drum Unit
                  c 35mm Cleaning Roller Drum Unit
                  d 792mm ITB (Intermediate Transfer Belt) FL0-0222
                  e 50mm Primary Transfer Roller FE3-0986
                  f 46mm Secondary Transfer Inner Roller FL0-0859
                  g 62mm Secondary transfer outer Roller FE3-4783
                  h 38mm ROLLER, SECONDARY TRANSFER,FR. FE3-0978
                  i 31mm / 15.5mm Developing CylinderFM1-B264 (DEVELOPING ASSEMBLY, Y)FM1-B265 (DEVELOPING ASSEMBLY, M)FM1-B266 (DEVELOPING ASSEMBLY, C)FM1-B267 (DEVELOPING ASSEMBLY, BK)
                  j 57mm ITB Tension Roller FL0-0127
                  k 76mm Fixing FilmFM1-D280 (120V)FM1-D281 (230V)
                  l 44mmVertical Path Roller FL0-1834ROLLER, DRIVEN ROLLER FC0-7610
                  m 2.2mm 36T Gear driving Fixing Pressure Roller FU2-1372
                  Good Luck!
                  • nathicana
                    • Aug 2008
                    • 335
                    Good Luck!
                    Where did you find the repetitive defects guide? I looked in the service manual and troubleshooting guide, must have missed it.
