instal hdd with sst without connect to machine
  • Momolio
    • Mar 2009
    • 30
    how i can install hdd with sst without connect to machine???
  • SCREWTAPE
    • Aug 2025
    You can't, you can use a USB stick but no matter what you would need to use the SST. That's like asking your car to drive without gas.
    • nivssluck
      • May 2008
      • 228
      i like that question...
      i didn't think that maybe i could try
      • smiley
        • Aug 2008
        • 615
        maybe you can copy the system then paste it to the hdd.
        there is no glory without sacrifice
        • Amstel
          • Aug 2025
          It is possible.
          I checked on the
          iR C2570 / iR C3170 / iR C3170i / iR C2570i
          iR3225 / iR3225N / iR3235 / iR3235N / iR3245 / iR3245N
          iR 5870Ci / iR 5870C / iR 6870Ci / iR 6870C / iR C5880 / iR C6880 / iR C6880Ci / iR C5880Ci
          iR7105 / iR7095 / iR7086
          iR C3380i / iR C3380 / iR C2880i / iR C2880 / iR C3580 / iR C3580i / iR C3080i
          CLC5151 / CLC4040 / iR C5180i / iR C4580i / iR C4080i / iR C3880i / iR C5185i PRT
          • xcopytech
            • Aug 2006
            • 1794
            how you do that?
            do you copy hdd with some software or use sst?
            • Amstel
              • Aug 2025
              I am register systems, preparing a USB Memory Stick via SST, then make the image from USB
              • Momolio
                • Mar 2009
                • 30
                Brilliant, how with ir5000/ir5020i/ir7200
                is another way???
                • Amstel
                  • Aug 2025
                  The car can go without gasoline, but only under the mountain!
                  • Amstel
                    • Aug 2025
                    Another way is to clone HDD via HDDClone.
                    • SCREWTAPE
                      • Aug 2025
                      is another way???
                      ir5000/ir5020i/ir7200 does not have this option, it doesn't support USB.
                      • SCREWTAPE
                        • Aug 2025
                        It is possible.
                        I checked on the
                        How is this possible! explain..
                        If you have some sort of external device that duplicates HDD's
                        The HDD connect right to the main controller on most or all newer models.
                        You will have to have the right hardware (compatibility).
                        Its not a bad idea to clone HDD's, But to ask how can it be done without the SST, this is the only program that I know that works when upgrading Canon copiers, it will always stay in the picture, unless Canon finds a newer way.
                        • Amstel
                          • Aug 2025
                          I'm sorry, I did not give an exact explanation, English is not my native language.
                          I use SST to prepare system for USB Memory Stick.
                          Then I make an image from USB MS.
                          When the customer has problems with the copier HDD or need local language.
                          You send them the image USB, is nothing more (SST, SM etc)
                          Customer restore the image to USB, swich ON copier with "28" in SAFE MODE, then makes the upgrade itself.
                          It's works really!
