Canon IRA C5235 PG-10 alignment
  • magictoner
    • May 2015
    • 11
    Canon IRA C5235 color copier, 320K, Magenta bar slides to one side in PG-10 test as the picture. It can not pass the Color Mismatch calibration. I did full gradation, changed the drum, the ITB belt, no result. I cleaned the patch sensor, even changed the patch sensor, it is still the same. I also took out, cleaned the Yellow and Magenta Laser Scanner, but it is still the same. Has anyone fixed this problem before? Please let me know, thanks.
  • wcanonw
    • Aug 2014
    • 404
    Re: Canon IRA C5235 PG-10 alignment
    Hello, I sent photos of the test type 6, of the drum unit.
    did you perform the atx-img adjustment or color mismatch correction
    • magictoner
      • May 2015
      • 11
      Yes I did many times. They don't help.
      • copier tech
        • 8164
        Try swapping the lasers around see if the issues moves to another colour.
        • nathicana
          • Aug 2008
          • 335
          Check the alarms (copier-display-alarm2) and look them up in the service manual.
          Run a series of pg5 pages of each individual color and look for deletions. There needs to be a full page solid image of each color or color registration alarms/problems may occur.
          Good luck on this pesky problem
          • techandtrader
            • Jun 2016
            • 334
            Reseat the drums. They might be slightly up out of pos.I have seen and fixed this before this way.
            I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
            • magictoner
              • May 2015
              • 11
              I did switch all drums. It didn't help. The only thing I didn't do is to change the carriage unit.
