[CANON COUNTER] Can I change COUNTER 1 ?
  • tjrtkdqja123
    Banned User
    • Feb 2022
    • 21
    [Misc] [CANON COUNTER] Can I change COUNTER 1 ?
    Thank you always to those who kindly reply. Happy New Year.
    Is there any way to change COUNTER1?
  • Brian8506
    • 1664
    Re: [CANON COUNTER] Can I change COUNTER 1 ?
    That's for the total count. What are you trying to change!
    • zoraldinho
      teacher-guide-expert-guru
      • Mar 2008
      • 5015
      Can not change 101.
      • tjrtkdqja123
        Banned User
        • Feb 2022
        • 21
        Thank you for your help
        I wnated to use only 102,124 counter
        Because there is a difference between the 102 counter and the 101 counter
        • copier tech
          • 8164
          101 is fixed you can't remove it from the 123 print out.
          โ€‹
          • onlyinnewfoundland
            • Apr 2013
            • 235
            You can switch it to 102/109 instead if you want to display double click meters instead of single click.
            Under service mode there is a CNT-SW flag that needs to be set to 1.
            copier>option>user>CNT-SW set it to 1. It'll change 101 to 102 and 108 to 109 I think.
            I usually add 124 or 125 to get a colour meter and add 501 to see the total scans.
