Canon IRA C5255 - E025-0x10 errors
  • copier tech
    • 8204
    [Error Code] Canon IRA C5255 - E025-0x10 errors
  • Brian8506
    • 1667
    Re: Canon IRA C5255 - E025-0x10 errors
    Copier/option/disp sw/T-crg-sw.change to 1. You can then remove toner cartridges by going into user mode maintenance
    • copier tech
      • 8204
      Thanks, but this is the problem the motors don't turn to release the door & uncap the toner then machine throws the E025 0x10 error.
      • Brian8506
        • 1667
        I'm not strong on this model but have you looked to see what service mode says? I know on the 5030 you could hand crank something in the rear but I never had to go there. Maybe whatever controls that may need to be checked or replaced. See if you can open this link. If not pm me your email address and I will send you the bulletin and a manual
        • copier tech
          • 8204
          https://www.techsupportpp.cusa.canon...icle=KB0278798
          If I use the tool I can manually open the door & remove the toners
          Yes I have studied the service manual on this error.
          • Brian8506
            • 1667
            Were you able to open the link I sent?
            • copier tech
              • 8204
              No. what's the log in details please ?
              • Brian8506
                • 1667
                Pm me your email and I will email you the bulletin.
                • copier tech
                  • 8204
                  Thanks.
                  admin@printerfirmware.co.uk
                  • wcanonw
                    • Aug 2014
                    • 404
                    4. If both the Main Drive Unit and the Set-on Hooper Unit
                    rotates together once the Main Drive Unit is manually
                    rotated while sealing/releasing of the container works
                    properly, check the sensor harness (to see if the harness
                    is caught, disconnected or physically removed).■
                    5. Replace the sensor which has been checked in step 4.■
                    6. (If the above measures do not solve the problem,)
                    Replace the Drum Driver PCB (UN4).■
                    NOTE: When checking the operation after performing
                    the remedy, go through the following to clear the error:
                    COPIER>FUNCTION>CLEAR>ERR; then, turn OFF and
                    then ON the power. After performing the remedy, perform
                    the toner replacement operation (from toner removal to
                    reset/recovery) from the Control Panel at least once, and
                    check that the replacement operation can be performed
                    normally
                    • Benjamin98
                      • Mar 2015
                      • 89
                      Hi there, did you make any progress on this E025-0x10 error?
                      I have an iR Adv C5240i that is giving me a E025-0a10 which relates to the Yellow sensor PS5. Checked the I/O in service mode and it's seeing the change but still comes up with the error. Swapped the magenta and yellow and it seems to have sorted but now getting a front cover open error and it seems to flit between the front and side covers. Anyone had anything like this before?
                      • Afivmd78
                        • Feb 2021
                        • 11
                        Did you solve this issue??
                        • Afivmd78
                          • Feb 2021
                          • 11
                          i think it is the issue with the Hopper
                          Did you fix it even i am having same issue throwing same error 0110 0410 i think its the issue with the hopper, not issue of motor and pcb, if you fix this issue please let me know the fix. And how you done it
                          • copier tech
                            • 8204
                            Yes, the fix was replacing the set on hopper ass'y (ours was cyan)
                            • Afivmd78
                              • Feb 2021
                              • 11
                              You mean changing Hopper Unit will fix the issue ??
