CANON C7565 only green and red light on. Not power
  • wcanonw
    • Aug 2014
    • 404
    hello, the canon c7565 printer has a problem of not turning on the screen and it does not emit motor noise, you only turn on the power and error leds.
  • wcanonw
    • Aug 2014
    • 404
    Re: CANON C7565 only green and red light on. Not power
    I attached photos of the problem
    • ElZero
      • Sep 2021
      • 24
      Not much information here. Did you try something to find the error?
      is the power led blinking?
      I first would check the Main PCB LED8, try to enter controller self diagnosis, download mode...
      could be the the power supply, riser-pcb, main-pcb...
      follow the check flows in manual.
