DX 5271F Flashes green no screen then warning light beeps than it powers down
  • Techboy
    • Dec 2014
    • 13
    [Dead] DX 5271F Flashes green no screen then warning light beeps than it powers down
    I am working on a 527F When power on the green light flashes under the Z than around thirty seconds the Warning light starts beeping and maybe another 30 seconds the power switch flips to off. The Operation panel never comes on in the process.
  • MunsterTech
    • Sep 2014
    • 377
    Re: DX 5271F Flashes green no screen then warning light beeps than it powers down
    Hi,
    If you check the service manual there should be a flow chart telling you the fault. I've had this several times on iradc257 turned out to be power supply
    • Techboy
      • Dec 2014
      • 13
      Originally posted by MunsterTech
      Hi,
      I do not have a service manual, the green light flashes 3 times pauses than 3 more time with the yellow fault light on. The screen that never lights is 5X7 screen with no manual push buttons.
      • craigster
        • Apr 2016
        • 201
        you need to check to see if any voltage is coming out of the power supply connector to the main controller but I had one recently and turned out to be main controller.
        • julka123
          • Oct 2009
          • 36
          hi ,
          replace dc Controller if not working you have faulty mn controller.
