C5550i Controller Swap
  • Elmo
    • Feb 2010
    • 541
    Hi all
    Looking for advise on canon iradv c5550i i have a machine with a faulty controller (wont boot just flashing standby light checked voltages and its the controller faulty)
    i have a used working controller removed from a scrap machine
    can anyone help me with the correct procedure to install a used board ie which do i need swap over the Flash PCB,TPM PCB, Memory PCB and Bypass PCB ?
    and is there anything else i need to do
    I Used To Live To Fix Things Now i Fix Things To Live
  • copier tech
    • 8142
    Re: C5550i Controller Swap
    Originally posted by Elmo
    Hi all
    Yes you can swap the controller from one machine to another but you MUST not swap over any other boards, flash, tpm etc etc so take them off you faulty controller & fit to the doner board.
