Canon ir advance c2230 distinctive ring ncu
  • lagustacat
    • Oct 2010
    • 51
    Have a customer that has a problem with using distinctive ring (D.R.P.D) he has the service from the tel company but i know there is a setting in the service mode > fax> ncu> cngdtct i just dont know what to set the bitswitch to there is no information in the service manual can anyone help.
  • bobburnsreb
    • Mar 2015
    • 233
    Re: Canon ir advance c2230 distinctive ring ncu
    KB0323658
    Distinctive Ring Pattern Detect (DRPD) and imageRUNNER ADVANCE
    6y ago6 years ago • 603 Views
    2017-02-10
    Product : All imageRUNNER ADVANCE Series
    Title : Distinctive Ring Pattern Detect (DRPD) and imageRUNNER ADVANCE
    Question :
    Is it possible to enable DRPD on these devices?
    Answer :
    Distinctive Ring, (DRPD), is a feature set that may be found on small fax type devices that are typically used on a small or home office. Since all imageRUNNER ADVANCE series are built around a copier platform and are not "normally" placed in these environments, it is not currently part of the current feature set. The ADVANCE series however, does have options for multiple line connectivity based on the model in question.
    • lagustacat
      • Oct 2010
      • 51
      Hi I am aware that the desktop models have D.R.P.D. built in where you can set this up but on the Canon Imagerunner models there is a place in the service mode under mode level 1 where there is copier> feeder> sorter> fax (under fax there is NCU) and under Ncu >cngdct because there is no information in the service manual i need to know what to change this to
      • bobburnsreb
        • Mar 2015
        • 233
        See attached #4 and #5
