Canon IR1435if restricted
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Ha-ha. I'm having some bad luck lately with off lease machines doing some weird things.
    Don't usually sell small machines and work mostly on Kon/Min. The warehouse didn't have any small kon/min machines and saw this IR1435if that was clean and only 10k on meter. It's for a good customer's home office. Just tested copying & ADF at warehouse and didn't bring back to shop to test like I usually and delivered right away. I had it pull an IP address at customer then had my IT guy call them to network it. He called me later and said machine wont let him do anything and keeps getting message "restricted" for everything. When he logs onto web page it is grayed out and wont let him UN-restrict. I was thinking maybe a way to reset back to factory defaults?
    Any help appreciated!
    Thanks in advance
  • Brian8506
    • 1664
    Re: Canon IR1435if restricted
    Menu/2/8/Menu/Function/Clear/Clear All/OK should default to factory settings.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4700
      Thanks Brian,
      I didn't see that in serv manual. I did see how to initialize all in System management settings. Should I do this as well?
      Take care
      • Brian8506
        • 1664
        • copyman
          Owner / Technician
          • Sep 2005
          • 4700
          Thanks again Brian. Your info worked! All good.
