Canon ADV C5235i old HDD fail can use PC HDD??
  • xamky
    • Jun 2019
    • 22
    [Misc] Canon ADV C5235i old HDD fail can use PC HDD??
    I have 3 of 52xx them HDD fail all. Can i use PC HDD. I already have FW.
    Thank you.
  • copier tech
    • 8131
    Re: Canon ADV C5235i old HDD fail can use PC HDD??
    Thank you.
    You can not just use any HDD Canon have a list of approved drives written in the firmware.
    However try the drives you have you may find they may work. Must be the same size 320GB.
    The only way to be sure is use an identical HDD to the one that failed.
    • xamky
      • Jun 2019
      • 22
      Thank you so much.
      I try use HDD form Xerox not work and make that HDD fail.
      • Elmo
        • Feb 2010
        • 541
        CANON HDD
        TOSHIBA MQ01ABF032
        320gb
        I Used To Live To Fix Things Now i Fix Things To Live
        • wcanonw
          • Aug 2014
          • 404
          You must format the hard drive before installing the firmware
