Canon ir 2520 e350
  • mramlawi
    • Jul 2011
    • 838
    Canon ir 2520 e350
    Distinguished road makes you jewel in rough
  • Qwert01
    • Aug 2022
    • 20
    Re: Canon ir 2520 e350
    Bad drum contact causes various codes. That's probably why you didn't solve the first code. From the back side, remove the clutch assembly, disassemble and clean the contact that goes to the drum.
    • mramlawi
      • Jul 2011
      • 838
      thanks , my problem solved after i replace a new Main control board with same version ,cos as I understand that theres some models with serial numbers can work on each other and others not
      • copier tech
        • 8144
        Out of interest how much did a new main controller cost ? wouldn't have thought it's worth it on an old machine like this.
        • mramlawi
          • Jul 2011
          • 838
          Thanks for ur comments and kindly note that its still sellin and our country we have lots of it
