Color Canon ADV maximum height (long) paper
  • xamky
    • Jun 2019
    • 22
    [Misc] Color Canon ADV maximum height (long) paper
    I sea in Devices and printer on my PC maximum height 1200 mm.
    But on MC can set only X 457.2 mm.
    It can do at 1200 mm.??
    • 23009
    Re: Color Canon ADV maximum height (long) paper
    I can't be certain on the Canon (and it would help to know which specific model), but on most other manufacturers the long media must feed from the sheet bypass, sometimes with a special optional bypass or exit accessory, and sometimes required enabling in service mode or user menu.
    Let's start with: What model? =^..^=
    • xamky
      • Jun 2019
      • 22
      I saw thay can do on adv c5250i
        • 23009
        The Users Guide says that the longest printable custom paper size to the bypass is 457mm. See for yourself:
        • xamky
          • Jun 2019
          • 22
          I got it.!!
          1.2 meter long print paper
          • fchu5959
            Field Engineer
            • Jun 2010
            • 100
            Originally posted by xamky
            I got it.!!
            Great,you found the MF-LG-ST setting.
            Now,for billing purposes,you have to set the proper counters.
            Do some research ;i am sure you will find it.
            Cheers
