Canon ir2200 adf registration
  • xoles
    • Aug 2025
    I pretty much just stick to sharp copiers, but the powers that be have sent me out to try to fix this canon unit. The leading edge registration is about 7mm off when using the ADF. Unfortunately I have no manuals on this, not even an intravia, it left when another tech left, go figure. Could someone point me in the right direction? I would greatly appreciate it.
  • davidj7
    • 1107
    whats your email i'll send you the service manual.
    a machine is only as good as your tech : source:screwtape ; the scary one
    • xoles
      Here's my home account, it's bigger
      kent@xolesfishies.com
      Thanks so much.
      • xoles
        Oh well,
        looks like I get to wing it this morning. Could still use some help, Don'y think I'll be lucky enough to guess the solution.
          To get into canon service mode
          *28*
          Feeder
          Then its either adjust or function but look out for docstop or an abreivation of that.
          • Brian8506
            • 1666
            Make sure reg is good off glass first. Then service mode/feeder/adjust/docstop. 7mm is alot check roller and pad in upper adf also.
            • xoles
              Sweet, customer is happy so now I can be happy. Thanks folks, looks like I found a good resource, maybe I can help out sometime.
