Canon ADV C5250 scanner not move to left when use ADF.
  • xamky
    • Jun 2019
    • 22
    [Misc] Canon ADV C5250 scanner not move to left when use ADF.
    My ADV C5250 got the big problem.
    When use ADF the scanner not move to left for wait document pass.
    And lamp not bright when document pass the copy paper full dark of page.
    But wnet put job of the glass Ok.
    Any body please help.Thank you very much.
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: Canon ADV C5250 scanner not move to left when use ADF.
    Check the adf switch. The printer does not know that the adf is down. When you lift the adf, the upper left corner of the printer.
    • Wild140!
      • Jul 2021
      • 18
      Check and reseat all of your connections between the ADF and the machine.
      • xamky
        • Jun 2019
        • 22
        use ADF copy the job dark 100% because lamp scanner not bright.
        Problem it solved.
        -Check the adf switch.--->OK
        Check and reseat all of your connections between the ADF and the machine.----> not work
        -Change ADF Unit and reader PCB---->not work
        -Change scanner unit ---->not work
        -Change ribbon cable form scaner unit to reader PCB ---> it work!!
