Hello all,
I have a couple of ir1600 with the same problem.
E000 appears so you reset the error and 2 days or 2 weeks later the error comes back. Change the fuser unit and again 2 days or 2 weeks later it comes back again.
I was told by another engineer that the switch for the left hand slide-out door can cause this problem, the switch in question (doorswitch2) is a simple make or break switch with a metal tag arm on it. I adjusted the arm to make better contact but this does not appear to make any difference.
Wondered if anybody else had come across this or have any other ideas.
Thanks in advance
Thanks in advance
