adf problem ir 3530
  • smiley
    • Aug 2008
    • 616
    adf problem ir 3530
    hi guys i have problem in copying from adf only in flsc size of paper it detect LGL then 1 inch is not been copied.i try to set ORG LGL set to 1 but nothing has change.any body can help me please.
    there is no glory without sacrifice
  • mrfixit51
    Lead Service Technician
    • Oct 2008
    • 1975
    Hi Smiley,
    I am not sure what you mean by "flsc size of paper ", but one thing I learned thru trial by fire, is that if documents are curled and lift up off of the flag sensors in the entry tray, you will get partial image problems. I along with several other techs fought a machine that the customer swore would do this, but when we tested it we always had good originals. It finally happened while testing with customer documents, that were curled. Holding down the tail of the documents produced good copies!!
    • SCREWTAPE
      • May 2025
      This my understanding of what your problem might be when you mention cut off images.
      First make sure you blue paper size dial on the cassette is set up for the right paper size, make sure that the cassette guides are set in place, check them out and see if they are broken. You can also try a tray width adj. and I would set ORG LGL back to 0 as well.
      enter Service mode, Level 1, by pressing * 2 8 *.
      then select FEEDER > FUNCTION
      under FUNCTION highlight TRY-LTR
      on the DF tray move the tray width guides to the LTR/11x17 positon
      now on the display press OK
      then under FUNCTION highlight TRY-LTRR
      on the DF tray move the tray width guides to the STMT/LTRR/LGL position
      once again, press OK on the display
      press the Reset key twice to end service mode
      turn OFF the power switch at the Control Panel and then the main power switch in that order. Then turn the main power switch back on to lock the settings into service mode.
      • smiley
        • Aug 2008
        • 616
        hi guys thank you for your quick response.flsc is foolscap size 8.5x13 inches.because if the adf detect it as LGL 1inche of the copy will lost.i will try all your suggestion guys.thanks again.
        • smiley
          • Aug 2008
          • 616
          hi guys thanks for help now the problem is solve.i fund out that there is a lg-st setting in service mode 2 has been set to 1.i compare the settings of working machine in this machine with adf problem and in option in last page i fund the answer. thank you soo much
          • mrfixit51
            • Oct 2008
            • 1975
            Were glad you resolved your problem,, and thanks for getting back to us with the resolution, I will have to look that setting up to see what it is used for.
            • smiley
              • Aug 2008
              • 616
              thanks again man.if you have service manual for this machine can you share it with me please.
