Ir 3245 E00315-00d error code
  • zawmyo201210
    • Oct 2022
    • 51
    [Error Code] Ir 3245 E00315-00d error code
    I turn on the machine and start printing, but it says wait for a while and stops doing any other work. Then the error code E00315 is displayed immediately.
    So what I can do is put all the circuit cards in the back of the device into another device of the same type and try it and everything is fine.
    It's still good for about a day after returning to the original. The next day it shows the same error code as usual.
    No circuit board has been appointed yet.
    Please help me.
  • GIUBOSS
    • 1436
    Re: Ir 3245 E00315-00d error code
    Description:
    There is an error in the image data.
    There is an error decoding JBIG.
    What driver are you using and what connection and port? You could update the firmware.
    • zawmyo201210
      • Oct 2022
      • 51
      Originally posted by GIUBOSS
      Description:
      I am using UEFR TCP/IP network driver. I have no copier firmware.
      I ma trying connection port.
      • techandtrader
        • Jun 2016
        • 335
        Prob just need to clean the Mirrors - lens with the tool under the copyboard glass. right side under your chin. run a ccd adjust and white levels. 1 hours service call to do that and check everything else.
        I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
